icprog & win xp
claytonstarbar
Hello i have version 104 of ic prog & windows xp, the problem is i cant put the loader file on my gold card, keeps getting the error
verify failed at address 000h !, ive tried version 104a of ic porg & win 2000 & xp drivers, com port 1 & 2 but still no luck anyone any ideas thanks.
H
hrista
Eh... do nothing, evrything is OK. Don't verify (uncheck in options meny)after programing, only during programing.
Error 0000 is because your PC is much faster then programers of ICprog. (runtime... etc).
ps I am very sorry of mu poor English.
TB
I couldnt get icprog to work at all with xp, even the newer version, so Had 2 format a old hard drive and put win98 on, and just use it for programming!! If you get error at oooh thats normally ok it should still work!!
H
hrista
PS
Hm.. I forgot one thing. If there is no driver (one that work)for XP or NT2000(I am not using that), you can emulate win98 on XP. In the properties of ICprog.exe you can check "XP emulate w98". Must work.
nobbly
Not in UK
Try using the IC-Prog XP driver. You can find it here:
http://web.tiscali.it/giavaleri/876/IcProgDriverXP.zip
Not tried it so I can't say if it works
nobbly :)
