If you're a Cband dxer...
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
...this one will blow your mind ..
I don't believe anyone in the UK has so far managed this one ..
Its mighty tricky at best ..
at least not on a set top box anyway.
4027 L
tp C3 Dunamis TV DVB-S2
MPEG-4 1200-3/4
8PSK
on Eutelsat 5 West A at 5.0°W
Well ...now I have..
and here's how
Due to it being Mpeg4 and extreme LSR and 8PSK..
Scanning this by inputting details was useless ..
As was blind scanning ..even with the smallest steps ..
So I used a previously scanned but now vacated slot ..already stored in the channel list..
This is why it will appear in the photo as 'Digital 1' ..which used to be a music channel on 4117
So instead of trying to input this channel data ..I edited Digital 1 to the correct frequency ...and edited again to change the symbol rate to 1200
With me so far ..
The F15 then tried to lock this hybrid channel ...but of course could not ..as all the PIDS and modulation type were all wrong ..
But signal level was now hovering around 6.5 db...
So I then went to the PID scan menu and forced the hybrid channel to rescan the PIDS ..
it took 6 attempts ..but eventually ..the red bar turned green ..and it went for it.
Now I have only to edit the chanel name from Digital 1 to Dunamis ..and we're done ..
Here is the proof it worked..
I suspect the increase in dish size helped ...but it might work for you..?
worth a try?
rgds
VS
remlap
Wales
Great catch and a great method, very glad TV Mundial is DVB-S2 QPSK just to say I've gotten a DVB-S2 C-Band broadcast :)
pride21
Sandown Isle of Wight
well done VS i keep trying for this channel all i got is 58% quality but does not lock.cheers
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..I left the F15 locked solid on this channel when I went to bed last night ..
Unlocked at 5db this morning ..
So I'm assuming a 6db unlocked level minimium is needed before the tuner will even recognise the signal ..even though the channel details are already stored.
This is true of many 8psk channels for me
6 to 6.5 db on the F15 scale ..appears to be the critical lock level.
Roughly translated for Pride ..this I think equates to 60-65 %
I'm assuming this channel is ver much Time of Day .
..so will try again this evening.
rgds
VS
tanka
cband ku band 52 birds 4dtv/vantage 1100hd vantage vt1 azbox premium plus Azbox miniME
canada
the 6 to 6.5 db the best for the scene to work are in the evening and late night
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
For the benefit of anyone thinking of having a go at locking this channel..
It just went into fragment lock ...approx 5:20 pm UK time ..
Signal is still weak but should begin to climb over the next few hours ..
it was approx 11:30 pm last night when I attempted to lock it and was successful as you know.
Don't be impatient and wait for the slow build up of signal which is why I used a hybrid channel already stored ..
Its then just a waiting game ..
Good luck
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Coincidence or functionality..
At the moment I'm undecided ..but here's what just happened ..
I left Dunamis locked with a picture ..
Went downstairs to Christina and pulled her third wing off ..to do some work on it ..
applied some body filler and left to cure ..
went back upstairs to check ..
No picture at all ..and no attempt at lock ..
The signal level had dropped from 6.2 db unlocked -7.6 locked...to 4.7db and no hope of a lock..??
Thats just removing 1 wing ..
I'm inclined to think ...these wings (at least some of them anyway) are quite efficient and are close to focus..but then ..I'm biased and want to believe this .
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The Wing is temporarily back on the dish 'till tomorrow ..
Dunamis is currently 9db++ solid locked so If you are planning to log this channel in ..or at least try for it ..
Now would be a good time..
rgds
VS
nelson_b
Contributor
been watching this transponder on and off for the last two hours ---
getting occasional very brief lock -- but not long enough for the receiver to pick it up :mad:
if the clouds would clear i might get it -- very frustrating --
pride21
Hi VS just scanned this channel a few momments ago its gone up in quality it hovers around 64% but when it reaches 65% it locks then drops out,its a bit drizzerly out at the momment may be better when it clears,at least the signal looks promising.cheers
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
A great pity you guys can't get this one ..
Superb entertainment ..
Some serious faith healing going on ..
A woman just praised the lord for curing her from Hormonal imbalance ...blindness in one eye ...brittle bone disease ..kidney failure ..and diabetes.
Maybe I should haul my ass over there ..and see what they can do for my MS..
rgds
VS
aceb
Prof Tuner 7301 /
Sussex
You need 68.5E Evan, there'e an entire satellite full of that superstitious claptrap, in the most part dodgy Americans preaching to gullible Africans.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Even more impessive on 20West ..they Excorcise Daemons ...Live on air..
I'm amazed at the number of people posessed..
Judging by the number of folk at a meeting ..it must average out at something like 1 in 20.
Retired human
Indeed. I've never seen so many religious channels on one satellite (68.5E).
pride21
hi VS had a go at Dunamis locked at about 65% quality so did transponder scan,evangel television came up the channel is 4027L 1200.Apid 0512,Apid 4112,Ppid 0512,could you check to see if its the same channel as Dunamis.cheers
aceb
Prof Tuner 7301 /
Sussex
Same here Pride, steady lock for me with CS reporting it at 8.3dB SNR
pride21
hi aceb must be the same channel unless they share the same transponder.cheers
I'd wager it's more than that
Father Gabriel Amorth, 85, has carried out more than 70,000 exorcisms
_http://www.dailymail.co.uk/news/article-2148071/Emanuela-Orlandi-Missing-girl-buried-mobsters-tomb-kidnapped-Vatican-s_x-parties.html
aceb
Prof Tuner 7301 /
Sussex
With a headline like that how can anyone not go read it!
remlap
Wales
Well im please to see this is coming in on blindscan, waiting to see if it locks will edit this post if it does.
