in need of help!
mean_d
hello,,
i just bought a humax irci-5400z straight from the dealer.can anbody tell how to program my hummy to recieve all the channels and how to connect it to my computer...and what is CAM and what is a Card ??
thnx alot ppl in advance
mean_d
please ppl i dont know what to do!!!!!!!!! help me out here!
The 5400Z may well need some work prior to it being flashed, what did the dealer say it could do?
mean_d
to tell you the truth i have no idea....and i dont know what to do!
Go into the conditional access menu and tell us what it says under the headings, possibly a good idea to ask your supplier if it is "upgrade ready"
PS. not trying to rub salt into the wound, but this is the information you should have researched prior to buying, as it mayt have influenced your equipment choice in perhaps a different direction.
Waht dish setup do you have?
