Dustbinlid
- Jun 2, 2009
- Age
- 48
- SkyHD
- Yorkshire
You liked that Grand National gag eh, like new york, so good they named it twice.
There wasnt really anything there that I didnt know, like I said Ive been around that side a while. However maybe then Ill go with your approach if you are unwilling to deal with this privately.
1-I understand the use of 'CW finder' is based on a computer with a Twinhan DST satellite card rather than using a 4:2:2 reciever, what exactly is it and how do you use it?
2-What tsreader?
3-What satallite would '1 West' be and is it normal for the channel to be on there used as a 'Back up' (or is this likely to be your reference about the feed being sent to 2 different satalittes?)
2-What tsreader?
