Installation of a hotel satellites
almraseel
Satellite hotel
iraq - baghdad
hi all
I installed a central shower system using one dish at a hotel
Have been installed for each room has its own receiver
Have been installed dish towards the Nile Sat
And installation of a Spanish unit lnb type televes
With four exits of the 2 v h and two of the high and low
After the installation has been linked with MULTI lnb Multiswitches
Existing and the 7 Multiswitches the type of strong, because the number of rooms 70 rooms
In short the problem does not function more than 2 of them only and the 5 Multiswitches more
Graduate of the pieces have changed the reference interest
I tried to link the type of amplifier is also strong "and Avaúdh
Work only 2 of Multiswitches
I wish the solution was possible and that the simplified picture of
All thanks to you all
Unfortunately the translator has not done a brilliant job, but I get the general idea.
We don't normally assist with commercial setups, but understand that in Iraq specialised help may be difficult to find.
Can you provide pictures of the kit?
almraseel
Satellite hotel
iraq - baghdad
I've installed the dish and you purchased the MULTI switch socket
The entrance to his 2 sat and 10 satellites out of the reception
Then been linked to cables that link the customer to a room
"Thanks for you help me
_http://www.strong-technologies.com/Photos/319_pic.gif
No, I need pictures of the installation. A stock picture of the type of switch will not tell me anything about why it doesn't work.
almraseel
Satellite hotel
iraq - baghdad
When I check signal moon is working only 2 MULTI switch
socket means only 20 rooms are staffed by satellites
and the receiver not working rest rooms
Well the multiswitch you show only has 17 outputs, and 17 inputs for providing signals from four different satellites. We need pictures of your actual installation.
almraseel
Satellite hotel
iraq - baghdad
Yes you are right
I use a device similar to a large extent his 2 inside and 2 outside the sat
in addition to 10 satellites to the receiver outside the service equipment customers
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Photographs of the installation are required in order to help you
Google translation
مطلوب صور للتركيب في النظام لمساعدتك
ralphmagno
naples italy
i can't even reply here.
i have no idea what he is doing or how many dishes or how many inputs he has on the multiswitch.
Ralph
Helps if you plug it in.
almraseel
Satellite hotel
iraq - baghdad
Hello "
I thank you that you are trying to help me
and this installation image you are working on
_http://www.hafr-albatin.com/hafrup/upme/hafralbatin99c83bbfe1.jpg
_http://www.hafr-albatin.com/hafrup/upme/hafralbatin597fb021f8.jpg
almraseel
Satellite hotel
iraq - baghdad
Google translation
Hello "
Thank you that you are trying to help me
That system is a complete mess. The whole idea of tap systems is to have units placed in positions where the individual runs from the aprtments can be a short distance and the cables between the units are of a high quality.
Some end users will not be getting all the signals they are paying for with what you have there.
almraseel
Satellite hotel
iraq - baghdad
Well "
I know I live in Baghdad
Now the construction of housing units and hotels here
And I would like to know what is best for me and at a good price
I have many requests and we are working on this system only
I want to know what is new and how it works and how is it possible installation guide to the piece
"Thanks to you all."
Well "
Switches are switches, unless they are faulty they will work out of the box as long as you follow the requirements for signal entry and exit (and plug it in).
_http://www.strong-technologies.com/Downloads/PDF/319_PDF.pdf
Have you confirmed the incoming signals at each incoming point is within the specifications given above ?
The importer/branding company has not provided any downloads on their page as they expect somebody proficient in setting up the system around the units requirements.
_http://www.strong-technologies.com/frmProdDetails.aspx?id=319
Have you contacted the company you bought it off ? They will be the ones first to offer service within their guarantee of sale
ralphmagno
naples italy
wow,
ok now we need to know how many rooms.
and how many satellites possions?
lets say that you want 24 rooms and 3 satellite possions.
you will need a 12 input plus 1 terrestial and 24 output multiswitch.
you do not have this here as best as i can see in your pictures.
if you want 4 satellites and 24 receivers for 24 rooms then you need 16 inputs and 1 terrestial multiswitch.
each satellite will have a quatro lnb with 4 lines from each dish.
each lnb will have seperate hor low hor high vert low vert high.
if you cros any lines the system will not work.
each dish will have to be the right size for your location.
if you need a 1.8 meter dish for each satellite then you will need 3 x 1.8 meter.
each will need to be aligned to the correct satellite .
on the output of the multiswitch you can not add more receivers and extra runs to other receivers.
2 receivers can not run the same port of the multiswitch at the same time.
Ralph
