Installing Virtual Radar Server - Raspberry PI
Archive-8
install the latest Raspbian Stretch Lite and enable ssh.
to enable ssh you simply create a file called ssh in the boot sector of the sd card. you can then log in to the pi via putty or similer.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -y lighttpd
next install samba.
sudo apt-get install samba samba-common-bin
then configure smb.conf
sudo nano /etc/samba/smb.conf
add this
[share]
Comment = Pi shared folder
Path = /home/
Browseable = yes
Writeable = Yes
only guest = no
create mask = 0777
directory mask = 0777
Public = yes
Guest ok = yes
the to save ctrl plus x and hit yes, then run this command to set up a user
sudo smbpasswd -a pi
it will ask you to enter a password twice.
sudo /etc/init.d/samba restart
samba should now be installed.
next we need install mono as virtual radar server is a windows program.
sudo apt-get install mono-complete
then install this
sudo apt-get install wget
mkdir VirtualRadar
cd VirtualRadar
wget http://www.virtualradarserver.co.uk/Files/VirtualRadar.tar.gz
wget http://www.virtualradarserver.co.uk/Files/VirtualRadar.exe.config.tar.gz
wget http://www.virtualradarserver.co.uk/Files/VirtualRadar.WebAdminPlugin.tar.gz
tar xvf VirtualRadar.tar.gz
tar xvf VirtualRadar.exe.config.tar.gz
tar xvf VirtualRadar.WebAdminPlugin.tar.gz
On the first run you will need to create an admin user and password so that you can get into web admin
mono VirtualRadar/VirtualRadar.exe -nogui -createadmin:admin -password:password
then you should be able to log in to the admin page of virtual radar server
http://127.0.0.1:8080/VirtualRadar/WebAdmin/index.html
For second and subsequent runs do this (you can add this to a script to boot at start)
mono VirtualRadar/VirtualRadar.exe -nogui &
Archive-8
add ftp to the mix, just in case samba didnt work for you.
sudo apt-get install pure-ftpd
We need to create a new user group
sudo groupadd ftpgroup
sudo useradd pi -g ftpgroup -s /sbin/nologin -d /dev/null
sudo chown -R pi:ftpgroup /home/pi/
sudo pure-pw useradd upload -u pi -g ftpgroup -d /home/pi/ -m
sudo pure-pw mkdb
sudo ln -s /etc/pure-ftpd/conf/PureDB /etc/pure-ftpd/auth/60puredb
sudo service pure-ftpd restart
you have just added FTP.
Is this a new image Chris, or one for newbies?
Edit -Sorry, not concentrating. A new VRS img. of course.
Archive-8
To activate ntp just do this:
sudo nano /etc/rc.conf
And then paste this in to the file,
DAEMONS=(!hwclock ntpd)
Save with ctrl + x and yes.
And reboot.
sudo reboot
To correct the time zone,
sudo ln -sf /usr/share/zoneinfo/Europe/London /etc/localtime
Finally
sudo reboot
