Intel Sat 10 or Paksat 1
hot_male
TechniSat Digi CI 2 DVB
with Irdeto Access Card (Ary Digital)
Brescia, Italy
hi
I do not find any appropriate section for help so I am posting here.
I am a beginner (or anything lesser than the beginner). I live in Bagnolo Mella, brescia(Italy) and I want to tune to IntelSat 10 or PakSat 1. I dont know how. Here are the informations I know about my system.
I am using TechniSat Digi CI 2 DVB with Ary Digital Card. I have two dishes of sizes approx. 80cm
waiting for help....:toke::-rofl2
What channels would you like to pick up, which languages do you speak, and how much have you got to spend ?
You are going to need something considerably bigger than 80cm for C-band.
Probably over 2m for Intelsat 10, 3 to 4m for Paksat 1!
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
satellite will be changed,then i hope signal should be stronger then..!
_http://teabreak.pk/pakistan-s-latest-satellites-paksat-2-paksat-3-paksat-4-288/26396/
equinox
4.5m Dish C-Band, Measat-3a
Philippines
For Intelsat 10, use these specs for satellite dish receiver installation:
68.5 East
Elevation = 5.1 degrees
Azimuth = 104.5 degrees
For Paksat 1, use these specs for satellite dish receiver installation:
38 East
Elevation = 30.9 degrees
Azimuth = 143.5 degrees
I hope this helps. :)
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hi!
you can calculate,the coordination data for every
country for each satellites on _satlex.de
hot_male
Brescia, Italy
I am a newbie thats why I am asking stupid questions.
I have observed that Hotbird 8 13.0°E is in my range then how can I catch it??
One thing more that when I turn my dish to a new satellite then it will be automatically available in my DVB box list or I have to do something else??
For Example, I want to catch Hot Bird 8 then what I have to do??
here are the lyngsat infos
http://www.lyngsat.com/hb8.html
http://www.lyngsat-maps.com/maps/hb8.html
I am qualifying this as I am in the 53 region
equinox
Philippines
If you will set up your dish in Brescia, you can point it to Hot bird 8 using the following figures:
Elevation = 37.5 degrees
Azimuth = 176.1 degrees
hot_male
Brescia, Italy
Assume that I have adjusted my dish according to your calculations then how I will be notified that I am connected to hotbird 8
I mean to say that how it will show on my DVB box?? Do I have to set the freuqencies or it will enlist it automatically??
