Internet radio receiver
vrlika
vrlika
TM6800,TM5200,MTI lnb 0.2,Darkmotor metal gears,14"t&k bracket,Triax 1.1m.
leicestershire
My missus wants to buy me internet radio wifi receiver for my :-candles so I can listen to croatian radio in bed.
But I dont know enough about them :confused so can someone advise me which one to get please ? And price is not a issue ...:)
thanks
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
I saw this model somewhere and kept the details.
Roberts WM202 Roberts STREAM 202 WM202 Wifi Internet, DAB & FM Radio
Covers DAB, FM and Internet radio stations either wirelessly or via ethernet cable. Also you can stream music from a PC as the radio has a built in player. About £130 I think.
Sateuropa one of our supporting advertisers sell Internet radios, click on my signature link and go to their site. :)
Go down to Other Multimedia, Wifi Worldspace. :)
vrlika
vrlika
leicestershire
Cheers guys for the info I will check it out.
If you're only going to listen to Croatian radio then you'll probably be OK with almost any Internet radio will do as most are listened to using Windows Media Player to play them.
But not the BBC! If you plan to listen to them then you need a radio that will understand Real Player transmissions that the Beeb uses.
HB13DISH
Retired Mod
Middle East - Israel
thanks
This is not as grand as an internet radio WiFi, but there are few FTA Croatian radio channels from Hot Bird 13E. Perhaps you can use that instead.
Might be a lot cheaper if you use your existing receivers or buy a small cheap FTA one and have it near the bedside.
pgh13
Midlands UK
Check out Aldi.....I think they're around 50gbp. The last time around My brother in law got one reduced to 30. You need a fairly good WiFi signal.
vrlika
vrlika
leicestershire
ok there are so many models out there but the ones that cought my eye are roberts w201 and roberts 202.
it's not just for cro radio i like to have the option to flick between uk and cro radio stations.
so will need better quality receiver.
cheers;)
selfsat
antena offset 1,20m
Portugal
cheers;)
Hello.
See this Denon:
h**p://www.denon.co.uk/site/frames_main.php?main=prod&MID=3&sub=3&fill=1&action=detail&Pid=279&
This system is good and have Ethernet port to listhen radio station by internet.
You need to buy an amplifier and a pair of speakers
They have one Kit for this.
goodbye
