bobbywise
- Sep 15, 2009
- Age
- 52
- Location
- Nantes
- Website
- www.robertwisbey.net
- Humax Foxsat HDR, Fracarro Penta Digit 68cm Dish at 28e, unbranded 60cm dish at 9e/13e/19e, EMP Centauri S8/1PCP-W2 switch emulating diseqc motor
- Nantes, France
Hi all,
I've decided to simplify my setup due to slight dish misalignment, old chimney brackets, and no longer care for motorized. I currently have the Fraccaro Penta 68 Digit, and may upgrade for the Fraccaro Penta 85 if my tree problem persists on 28E.
I live in Nantes, France, and because of some trees (which have grown) there is a borderline limit according to the dish pointer app. 23.5E and further south are totally fine (boy, life is ironic).
I've ordered an Invento Multiconnect, and want to receive 28E, 23.5E, 19E and 13E. Usually, you would set this up with 19E on the principle/central LNB for the dish, and offset the others either side of it. However, because I want to be sure to have the best alignment for 28E (which is weaker than the other satellites), I'm thinking of setting up the principle/central LNB as 28E and offsetting the others instead. If then it's physically at the limit for 13E on the extreme edge of the bracket, I would then move the 28E on the other side of the centre part of the bracket, but leave it centered on the dish.
Are my propositions viable, or should I just set the dish up based on 19E like usual ?
With Well Wishes,
Rob
With Well Wishes,
Rob
