Iplayer not working on Humax Foxsat
John Parton
Sagi Parabol dish, Humax Freesat box
Stavanger, Norway
Got iplayer working on all my computers in the house both wirelessly and connected via LAN but cant get it to work on my Humax Foxsat. Says the 'media does not seem to be working' all the time. Any ideas?
How are you getting past the geolocking problem? I would guess that whatever method you're using is being bypassed by the HDR.
Id guess the same as Paul - and say your vpn software is on the computers not on your router.
John Parton
Stavanger, Norway
Scratch that - Iplayer only works on my main comuter with the vpn software installed on it (thought I had other computers running iplayer - must be confused)(
Must be a way to get other comuters and my humax to get iplayer working through my VPN (I#m in Norway by the way hence need of VPN)
You need to do it at router level.
