IPTV Box with VPN setup?
mark joslin
1.2Mtr Chan-Master Dish & Various RXs
Mojacar, Ameria, South-East Sain
Hi, Can anyone help, I am new to IPTV and like so many expats here in Spain now need to buy an android media player to use for streaming some UK TV progs (BBC,ITV, CH4,CH5) but I am a bit unsure if they all have the ability to setup a VPN client, to gain access to ITV Player, BBC Iplayer etc
Many Thanks
Mark
gambit
Lancashire
60cm fixed 28E
Hi Mark
A Smart DNS will have less impact on your broadband speed than a VPN and is easier to set up.
Before you go down that route I recommend that you use the Filmon app or add-on. Not necessary to hide IP. Get that working first on your Android or other suitable set top box. You can add a VPN/proxy/SmartDNS later.
There is an Android OpenVPN client app although will not work on all Android boxes. If you really must use a VPN probably best to install the client on a router.
This blog contains a lot of background, including how to set up UK TV on a Raspberry Pi.
http://jamestonbradley.wordpress.com/2013/12/03/xbmc-youre-one-stop-shop-for-uk-internet-tv/
