irdeto access on laptop
acer4000
acer laptop humax and opentel reciever
ksa
are there any drivers for the irdeto access cam p/n 901275? whenever i insert the cam in my laptop which is acer travelmate 4000, winxp just says hardware pcmcia mtd2...found and searches for drivers. pls help.
Burnham Beech
901275 can't be changed on a laptop.
And the older cams that can be changed need windows 95/98/ME.
acer4000
ksa
thanks a lot burns u saved my time.
kamaleon
skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
str8 frum da wesside innit?
are you saying that one can put a cam on a pcmcia slot on a laptop and do something with it?
kamaleon
interesting... please tell me, what could one do with one then...? program it? read cards?
Burnham Beech
You can change the cam into a different version. With old Irdeto cams you can load various versions of Freecam. The Aston103 can be turned into a nagra or crypto cam.
But these cam conversions have little use now.
Yes, used to program my old Freecam with the laptop, those were the days. :)
You can still do the Matrix and X-CAM with the laptop, or a PCMCIA card in a PC. :)
kamaleon
Hmmm... interesting... could you then use it as a ci for progdvb or other software? i bet not...
