IRS splitting signal
gmth63
Sky Hd and Sky +
Quad Core
Surrey
My local council are going to install an iRS system which will have a faceplate with TV, Radio and 2 Sat connectors on it.
At the moment I have sky Hd in one room and sky plus in another connected to my satellite dish, but I will have to remove this when the IRS system is up and running.
What I would like to know is there anyway I can continue to have both sky systems working using this IRS system, they wont put an extra feed in for me so are there any switches or devices I can use to continue with the same set up I have now.
Hope this makes sense.
Thanks in advance
GM
satelliteman
Welcome to satsuk,
For your set up and allowing for full record functionality, you'll need four feeds for the two skyboxes.
You might have to pay extra but it would be well worth it to get 2 pairs of feeds into your place.
