jkeys mx29LV160BTTC-70
kbenjila
Has anybody the jkeys for this chip please so I can revive my mvision 7000_e+
thanks
tamazgha2003
dreambox 500s
tamazgha
i can only give you a link but dont ask me how its work for this receiver
h**p://www.klgalaxis.com/texas/MvisionE+JTAG.zip
slugworth
gsky v7
New England
I would try jtag_up or skymax1.3 instead of jkeys.
You don't have to play with .def files.
Both programs can be found on the net if you search.
kbenjila
Hello,
I tryed jtag_up...start..then erased the flash and then tryed to write a flashbin..but after a while it says:Error writing flash at address 7FE00000 ACK = 00000100 Write Flash END
Do you know what goes wrong
thank you very much
slugworth
gsky v7
New England
Jtag_up and skymax work better in win98. Some people say it works
in winxp but I could never get it to work.Hard drives are cheap now,
I suggest you get a spare and throw win98 on it.
Those programs will work in win2k, but the erase function may say failed
when it actually does erase the flash. I just ignore and write a new flash
anyway.Jtag_up is actually a later version of skymax1.3.
Skymax2.2 doesn't let you save the flash first, so I don't use it.
slugworth
gsky v7
New England
Skymax is sometimes listed as skymax_up if you are having trouble
finding it. Search for skymax_up or skymax_up1.3
kbenjila
I have tryed it with a win 98 machine but it keeps stucking on this error (also with skymax) It looks like it won't go further on...is there anything else what I can try please...or de jkeys for this chip
i appreciate your help:(
