i did send back my box but i know some people fix that by using serial flash enforcer
DM800 Clone Serial Flash Enforcer
'' DM800 Clone Serial Flash Enforcer
Made by and inconjuction with the Clone manufacturers!
Use if DreamUp will not connect to your 800 Clone.
read pdf files inside. ''
here is two solution
No ca found by 2nd stage loader
This can be done in 2 ways.
1) You have to have a working dreambox.
2) DM800_repair, you alter dreamup to be able to use greyed buttons.
Now for the first sollution.
1) Connect working dreambox DM600/DM800.
2) Open dreamup, press connect.
3) When dreambox is found by dreamup, insert Null-Modem cable in
the broken dreambox.
4) Press flash button, and chose a firmware.
5) The flash progress will probably hang, its OK.
6) Open dreamup again, connect the broken box, press connect.
7) If all went ok, you can now flash box again, (Use only serial
communication)
Now for the second sollution
1) Connect broken dreambox DM600/DM800
3) When you see second loader error popup, just press ok.
4) Open _http://www.gsmsweden.com/forhike/sat...stage_pack.rar
5) Drag DM800_repair in front of dreamup, and press dream multimedia logo.
6) Now press the greyed Flash button, and chose firmware.
7) The flash progress will probably hang, its OK.
8) Open dreamup again, connect the broken box, press connect.
9) If all went ok, you can now flash box again, (Use only serial
communication)
am i allowed to send link for download soft?? if not please fell free to delete
_http://rapidshare.de/files/48504554/..._pack.rar.html
