KAON file for taquilla ?
nonee
satellite free view
uk
taquilla on astra gone ,I have kaon reciever, please anybody can help me to get new file for kaon
H/W 16-c0-A1
thanks in advance
nonee:(
Mickha
North West
D+ has just gone down, we're still waiting for more information, if you want the football try TPS Star on hotbird.
Best wishes
Mickha
nonee
satellite free view
uk
Thanks MICKHA but I have astra dish and I cannot see another sat , so how I can get new file for D+ for kaon reciever , when you get please put on forum.
thanks in advance
nonee
Mickha
North West
Hi nonee,
at the moment it looks like a key change, if that's all that's happened these should be posted later today or tomorrow.
Because AU files were around D+ turned off this facility and so we just have to be patient. When they are available they will be posted on all the relevant sites.
You might want to look into motorizing your dish as this occurs frequently, with different packages opening and closing.
Best wishes
Mickha
nonee
satellite free view
uk
Thanks MICKHA
I always check files on this forum and alsat forum,really these are very good and helping sites.
can you please tell me any other sites where I can get new updated files for kaon recievers?
thanks and regards
nonee
Mickha
North West
nonee
satellite free view
uk
Thanks MICKHA
actually I am looking for patch files for kaon recievers like these files
http://alsat.co.uk/forum/showthread.php?t=35470
but these are not updated one and I am looking for file
H/W 16-c0-A1
updated with D+ astra
if you please find any information about this today 17-04-06 updated file
please tell on this forum.
with best wishes
nonee
Mickha
North West
Hi nonee,
the new codes are not known at present, and it could take a while, all you can do is be patient.
Best wishes
Mickha
Perixeri
TBoston 4500
Spain
Digital + Spain started a battle against piracy on Monday. Receivers firmwares should be changed I'm afraid and masters are working on it. It's not as simple as a key change. All you have to do is to be patient and as soon as a medicine for this disease appears you'll know about it.
vjeta
Metronic K-Box Single ;
Univers 4201
lisboa
hi
its in portuguese and its for hispasat but all portuguese and spanish are around that issue .
goto the portuguese section -> kaon section . if there is an update for D+ its there .
we are all going crazy with that .
vjeta said:
hi
There arent any updates for D+ at the moment. Its down for everybody.
Pay for it or do without ;)
nonee
satellite free view
uk
We all know that D+ is not working , but can anybody or modrators or appolo tell me that with the same file for KAON receiver available on alsat forum
Can I see any other channels on any other satellite instead of astra 1
with this file H/W 16-c0-A1 appolo files, ??
please tell me on which satellites and which channels can I see with this file??
thanks in advance
nonee
Mickha
North West
Hi nonee,
the patch will probably open TPS on hotbird 13E, and if you update the keys Cabo on Hispasat 30W.
Best wishes
Mickha
nonee
satellite free view
uk
thanks mickha
you always helps me, so tomorrow I will change the direction of my dish to hispasat 30W, and I will see the cabo is working or not.
But if not so how can I enter the new keys in this patch file?
because I know only to programme my KAON receiver with kup230.
but I dont know how to enter the new keys in patch file like H/W 16-c0-A1
So please can you tell me if I will not get cabo in hispast 30W with kaon receiver patch by this file , so what to do ???
please reply me with detail.
thank you very much mickha
regards
nonee
tamazgha2003
dreambox 500s
tamazgha
you can use kaonkeyloader
see attachment
nonee
satellite free view
uk
Thank you tamazgha
but I cannot download your attachment for
sunny kaon keyloader.zip
maybe somebody disabled this?
what to do???????
can you send me on my email?
thanks
nonee
You cant download it as its a moderated attachment. Having had a lok at it, its ok so give me a couple of minutes and I'll moderate it:)
nonee
satellite free view
uk
thanks tamazgha
nonee
nonee
satellite free view
uk
thanks tamazgha for kaon key laoder,
I uploaded my kaon receiver with this kaon sunny key loader and I enterd the receiver menu after pressing YELLOW +BLUE+GREEN +menu
please can you tell me that from where I can get the new keys for this to enter in receiver by remote control???
thanks in advance
nonee
john_graydon
Dublin....Ireland
@ Nonee
Im suprise you dont have h*tp://sat.us.pn/ bookmarked as you will find all you need there. Always make sure you load the correct firmware.
