mhku said:
Those keys were always out of date.
Real Dreamboxers do it manually ;) or maybe with a script...
I wannabe a 'Real Dreamboxer' !
Only just started using the DB again in earnest as the footy season has started, I was spoilt in the past by the lazy mode of updating automatically via the blue button.
So have been forced to bite the bullet and find out how to do it 'properly', think I have sussed out what to do, seems fairly straightforward.
Formatted the USB and had a fresh start.
Installed the official Release 1.10 in flash, then thought would go for 'SatNews DaVinci 5.8 R110' to USB as presumed 1.10-based.
Found a rar of ....tar.gz EMU files on the F**F*les site, put the camd3.853 one in /tmp and ran the 'manual install' from the SDT boss panel.
So far so good, now have an EMU cam to play with, but of course not much use without any unmentionables..
Found a camd3.k**s file from the same place and dropped it in /var/k**s, restarted the cam but nowt.
Well not quite nowt, if just left for a few minutes the channel would clear for a couple of minutes then just freeze, so I am nearly there.
Any advice appreciated, or maybe a better combination of image and cam perhaps?
![Smile :) :)](https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png)
