New Channel La 7 HD and La 7d HD (Multistream)
Adam792
Cheltenham
Not sure if these have been here long but I've just noticed a new multistream DVB-T feed on 5°W carrying La 7 and La 7d in HD.
12606V
35000
DVB-S2 8PSK 2/3
Multistream: Stream 1
PLS: Root+8
This now makes all 7 main Italian channels available 24/7 FTA on 5°W via multistream! Including Rete 4, Canale 5, Italia 1 and La 7 all in HD, plus the Rai HD channel (which flicks between showing Rai 1, Rai 2, and Rai 3 programmes in HD) and Rai Sports 1 HD. As someone without a Tivù Sat card I don't bother with 13°E for Italian stuff at all any more (other than radio). :D
Ndongmu
3.10m, 1.30m , 1.25m motorised and 90 triodale dish
Padova
Hi Jamie A, which type of satellite card are you using. I was thinking of getting the TBS 5925 to used it as a satfinder, may you advice me. Best regards
Jamie A
I'm using the TBS-5925 USB version. It works well, not had any problems at all with it.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin + SF8008 SUPREME + Uclan Ustym 4K PRO Twin
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Strange. I'm not picking these up. I've just done a blind scan for FTA only but its only picking 30 odd channels (all of the French ones) but not an Italian one in sight.
Mind you, look at all the failed TPs. Perhaps 80cm is too small for these
Edit: just realized I probably need a sat card to see them! :D
VodzigorLans
Setup is down atm
RU, Saint Petersburg
One more frequency for those channels 5W 12711H35492 (35500) 2/3 PLS encrypted...3 package copies in multistream.
Gold 7 is working maybe there are one more code...
Check it.
MCelliotG
Thessaloniki, Greece
Thank you, will connect my TBS and report back in a moment! What is the PLS code?
VodzigorLans
Setup is down atm
As i mentioned after a quick attempt i got pls code 7 and type Gold. Signal is not strong for me...
Im not sure if code if correct since all 3 streams are same.
MCelliotG
Now if I told you I thought the Gold 7 was actually the Italian channel 7 Gold? lmfao!!! :p
Yes, coming as said, three duplicate packages but the signal is quite lower, coming only at 10.3db!
MCelliotG
Note that it's also coming with Root+2048 code!
astra19
98cm motorised technomate. 50e to 34.5w
Europe
A bunch of shopping channels have appeared on the TP that La7 shares.
12669H, 2/3 PLS Gold 262140, Stream 1
The quality is awful as expected. I'm not sure what it is about Italian TV. On Hotbird too some channels have a decent picture quality but absolutely horrendous audio. These have both terrible audio and video.
