Labgear S501
Woody
b
West Scotland
Looking for a bit of help if possible. I have always in the past used my horizon meter which did everything I needed for standard sky installs (not sky Q) & freesat installs but my meter failed a while ago so I bought a Labgear S501 which I am struggling to use. For standard sky / freesat I have the lnb type set to Ku band on Ku_Astra 28.2. What the should the rest of the settings be? I just need to know H/H, H/L, V/H, VL signals.
Also I some times work with multi switches. If I connect direct to a quattro lnb what should the meter be set to to allow be to find each signal over the 4 cables, H/H, H/L, V/H, VL.
Thank you.
