For Sale Laminas AS1800 + Jaegar 1224
Retired human
Hello,
I am going to start a clear out of my garage as we are potentially doing an extension, which means garage space will be used for other purposes.
The first one is the Laminas 1.8m dish which has been in the corner for a good few years now, unused, along with a, used, 1224 motor.
There will be some minor restoration work required for the 1224 motor but it's in working order. Just needs a clean for the most part.
There will also need to be some mounting work required for the Laminas to attach it to 1224 as I used the bits for the Channel Master.
Here's the dish when it was installed (on the left obvs). The motor in the picture is NOT the one for sale - it will just be a bog standard 1224 motor.
I would like £500 for the lot - will not split as the dish is unlikely to sell on its own...
Collection only from North Somerset (either personally or using a courier/AnyVan etc.)
uploadfromtaptalk1461521310369-jpg.92718
Manikm909
Small'ish Dish Man
Kent, UK
good luck with the sale! not easy to shift dishes i've learned, unless you give them away.
Retired human
I don't expect it to be a quick sale (if at all) but I'd rather keep it than give it away.
With abundance of relatively cheap online streaming from the likes of Netflix and Disney etc. it's becoming more difficult to justify a satellite system.
