Link a receiver to PC
razvan_ro
HD addicted
Hy there. I recently got an Vantage HD 7100TS satellite receiver and i want to link it to my htpc because i want to store my recordings in real time.
Both my htpc and my receiver has an USB, ESATA and ethernet port. I tryed to link them with an usb cable but no succes.
Can anyone tell me how to link them?
HB13DISH
Retired Mod
Middle East - Israel
Have you tried using an Ethernet cable with the correct IP settings?
This is what I use between a Dreambox and the PC.
razvan_ro
HD addicted
I assum that you use a crossover wire to link them. I don't think that my Vintage is so smart to do this but i'll try.
i'll let you know if it's work. Thanks anyway!
HB13DISH
Retired Mod
I use a router and ordinary Ethernet cable.
developers
www.development.plus.com
Vu+ Solo 4k PVR using Enigma2, Motorised Triax 1.1m, fixed Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2 & Satlook HD
Cheshire.
Shouldn't a router with straight ethernet cables work the same as a cross wired cable pc to box? If so that should not be a problem.
Does anyone know if it's possible to communicate with a Topfield 7710 hd pvr?
