LNB c/ku band
antrabe
dreambox7080 dm900 viark droi
spain
which is the best lnb for both bands c and ku with only one lnb?
Archive-8
C&Ku combos imo are always a compromise.
If you have a prime focus dish you might be able to use a bullseye feedhorn.
Laser
Nothing for a CM dish I guess that will do both ?
archive10
Titanium satellite has a Combo (CK1S), to which you can fit a conical scalar. This may work to some degree, but remember the scalar is different for C and Ku band, so it will be a compromise design.
This may work for normal TV watching, but if you are motorising and/or feed-hunting anyway, I would think you're better off with an off-set C-band mouned slightly left or right of the center Ku.
With an offset dish like the CM design, you might get better results fitting the second (C band ) LNB, above the Ku though you will have to fit a second motor to move the reflector to the correct point.
If you have the money and space, put up a second dish.
archive10
Erhm... I didn't write the last two paragraphs (highlighted).
While the claims may be perfectly valid, I cannot vouch for them, as I have no experience in using these techniques, and therefore cannot give guidance in that subject matter.
antrabe
spain
the next week i could test a 1.5m Fte dish to check if i can lock astra 2Ein south of spain near malaga with single lnb let see...
aceb
Prof Tuner 7301 /
Sussex
"Last edited by a moderator: Jun 10, 2018 "
Surely it would be better to add as a new comment rather than tag it on anonymously to someone else's post?
archive10
Well... classical case of editorial integrity.
One wonders what else has been written by whom?
Was acually somewhat upset by not so much the editing, but more that no-one owed up to having pressed the wrong button or whatever.
If not the moderator in question, then at least the editor-in-chief should look upon this with grave attention, and go dig in the logs to clarify and action somthing.
Have actually felt slightly restrained lately about posting - I somehow feel a slight loss of honesty and integrity.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Yes, it's strange if your post has been edited by adding text, not being your text.
Hope it really is a once and never again occurance.
greetz,
A33
Hmm that might have been me, it should have been a reply to the o/p, with just the two last paragraphs. The ‘editing’ part would , or should have been just a spelling correction of my own text, not including a previous post.
I have been using an exceedingly small screen when posting out of doors , an iPod nano 6, which comes complete with a ‘finger trouble’ keypad
a33
XSAT410
Rebox RE-9000
The Netherlands
So, it seems clear now that you didn't intend it this way.
Do we also hear a 'sorry sorry sorry' here? That would help me, if I was the one affected. So maybe that applies to st1 as well..
greetz,
A33
antrabe
spain
im already playing with my dish 1.5m i can receive ses6 40.5W but by the moment only 8 transponders anyone knows a enigma2 channel list to install on my dreambox8000 will be easier to get more C band channels
thnaks
antrabe
spain
Somebody knows where can be bought the lnb gardiner 70db 12K?
dreambox1959
46.3N-4.3E-FRANCE
france
is it ok to have circular polarisation swap : i got R when i choose L and L when i select R . my C-band lnbf is put beside the KU lnb (which is at focal) .
The dielectric plate in the feed should be turned 90 degrees
dreambox1959
46.3N-4.3E-FRANCE
france
i m lookink for a "polo pipe" (pin polariser) as it s named on posts.
do you know a dealer for european customers ?
What is the centre frequency you are looking for, plus the end stops of reception ?
or precise values for made it ?View attachment 124522
When I checked out supply of these pin pipes a while back I only found South American suppliers. They are used quite a lot in Brazil for 40.5W and there are a few suppliers who will ship to Europe but the postage costs are quite high. It would probably need a small group buy to get the postage costs per unit to a reasonable level.
