Low symbol rate transponders.
aceb
Prof Tuner 7301 /
Sussex
I'm trying to see how low my Prof card will lock and the best so far is Joe FM on 16E, 12680H, 333, 1/2. The only problem is I've had no audio from it so far using VLC. Anyone confirm it's on air or not?
I can successfully play the French radio stations on 8W, 12748H, 717, 1/2. Any other low SR signals about?
hairybadger
Bricoleur
46.1N 6.4E
see sig
Openbox S10 won't go lower than 1000, just tried :( Is a shame because I get 16E pretty strongly.
aceb
Prof Tuner 7301 /
Sussex
Maybe they aren't on air, I've successfully locked Radio 538 also on 16E 11070H 333 and have audio playing through VLC. I can't use DVB Dream or any of the regular DVB programmes to lock <1000 SRs either HairyBadger, it's due to the Prof driver. I have to have direct control using Crazyscan or use Crazycats modified BDA file for use with Alt-DVB then set the transponder details manually, unfortunately nothing will blindscan this low.
hairybadger
Bricoleur
46.1N 6.4E
see sig
Presumably there must be some consumer hardware available that can read this SR without fiddling, otherwise what's the point in broadcasting it? Retransmission?
aceb
Prof Tuner 7301 /
Sussex
My guess, at least on the Dutch ones are they're feeds into the cable networks.
bonou2
strong 4500, openbox X801, vantage 7100ts, vantage X201 CI, goldenmedia 9080,goldenmedia uni-box2,tbs6925+,inverto black ultra+C120,panorama er-861, zinwell lnb 15K C- band,intersat 20K
with amiko alien 8900 hd you can listen all radio stations with low <1000 SRs
idem with Sunray800se
remlap
Wales
Nope from what I understand they are for transmitter sites.
bonou2
digi247
NW
see sig
Not quite the same but i have had both the low symbol rate radio stations on my DrHD Grand Triple on 23.5 east 12640 V SR 0940 & 12660 V SR 0477 both work perfectly i shall have a peek at the others mentioned here
digi247
NW
see sig
Yep just to confirm took a little time to lock but has scanned in 12680 H SR 0334 1/2 scanned in as JOE FM BU
Regards
