smudger_smith
- Jan 1, 2000
- Age
- 81
- West Sussex
Hi
Being a tight-fisted sort, when I was given a Madonna programmer by a good m8, I was reluctant to discard it when I found it wouldn't work reliably with Cardwriter V2.06 These programmers were available from Ma*king several months ago but are not mentioned on their web site now. The programmer works fine with V1.87 - unfortunately V1.87 apparently can only deal with basic FunCards. V1.87 doesn't seem to be able to program external EPROMs greater than 8KB. I needed to load 2 FunCard 4s (32K or one FunCard 5 (64K to upgrade the f/w in a Joker/BlackIce CAM. I got into the 'Insert Card 1' then 'Insert Card 2' loop which indicates that not all the code is present. I found V2.06 and, strangely, this worked with the programmer just long enough to program my FunCard 5 since when I get a 'Sync error' every time I try and use V2.06 with a FunCard. V1.87 will see the 90S8515 CPU on any of my FunCards without any problem but 2.06 - nah! I suspect that there is a cruital timing margin which V1.87 deals with OK but V2.06 fails to handle consistently. Has anybody come across this problem? If so how did you resolve it? Is there some other s/w which will handle FunCard 4, 5 & 6?
Cheers
Smudger
Cheers
Smudger
