Mart74
- Feb 12, 2009
- Age
- 50
- Mac based
- Oxon
Hi Guys
I've just spent a while searching but can't seem to find what I am after so thought I'd make my first post!!
I've just put a TV into a bedroom at home and am having problems with the ariel connections. I've run some ariel cable up into the loft and cut the main ariel cable that feeds our downstairs TV. Ive then put this into a 3 way splitter and taken the new ariel plus the old on off of this. The problem is now the digital signal is not as good as before. I can only assume it's because of this 3 way connection. I've checked the joins and they seem ok but I'm wondering if the connecting box and fittings I used are a bit crap (bought from homebase).
Has anyone got any ideas?
Applogies if this in the wrong section
