master code use
nr66
hi everynoe,
can anyone explain what are master codes for?and how are thy used?
many thanks,
nr66.
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
Master codes are used to acces a page on your STB MENU, where you can edit keys to open scrambled channels. The master code is used together with a procedure, and they both differ from receiver to receiver.
If you are looking for MasterCodes for your receiver, follow this link http://www.satellites.co.uk/php-bin/forum/showthread.php?t=34148 , and look at the bottom of the first post. On the same post, you will also find where to update your receiver software.
Hope it helps ;)
nr66
Hi DeepDiver,
Thanks very much for the info about master code use. I try that on my echostar 2110 2ci.Can't wait.
regeards,
nr66
rcapili
My Setup:
XSat CDTV410 DVB
ORBSAT O.S 525 LNB
60CM Satellite Dish
Philippines
Can you please tell me how to use the master code for xsat cdtv410?
lassali
skymaster 24
Australia
hello,
does anyone know the master code for skymaster x24?
please help
tamazgha2003
dreambox 500s
tamazgha
let me tell you that master code are ONLY ussefull when you forgot the parental code(pincode)
normaly when you buy a receiver the defuallt code = 0000
but you can change this any time and when you forgot this new pincode you can use the mastercode to get acces again to any pages in the menu
and it has nothing to do with scrambeld channels
castelino1
iam a sales man for technosat reciever
kuwait
hello all my satlite expert , i want to ask a question , how can i get
polsat ?
can you send me please viacess code and nagra codes latest 1.
thank you verymuch for this satlite explainer.
boro_str
i have a kaon reciever pls give me master pin
macedonia
kaon 220 pls pls
i need the master key
nouchus
windows vista
sharjah
any one having master code for truman tm150 ultra..plz snd me..
