MM & Nokia 9902S ... ?
piccolus
Hi there,
I new here so I do apologize if my questions have allready been asked and answered (I did find it in the archive :>) )
Question are :
- I've read around the net that MM doesn't work fine with the nokia 9902S ? Is it right or not ?
- It seems (for me) that the nokia doesn't have a menu entry to manage the IC module, then the cam. So ... how to program the MM if needed ? Does a latop computer works for it (by copying the needed files -loader + eeprom) and wich software is best for that purpose ?
- Last ! : Do I understand right that to use the TPS decode files I need a fun card 6 ?
Thanks for answers ...
best regards
You could reprogram your MM using a CAS interface, use the Matrix reloaded software, then you won't need a card.
piccolus
Hi Rolf,
To be sure I understand well ...
- the CAS interface helps to download new system to the CAM when this is not possible throught the staellite receiver.
- the matrix reloaded CAS handle TPS decoding without any additionnal fun card
Am I right ?
best regards and thanks a lot
