MM & Strong 4350 ( not so strong !! )
S
smeftahi
Hi all
I have SRT 4350 which I understand from some good advisers does not handle MM very will except MM1.01 with Penta1.11.
If I am unable to get hold with MM1.01 can I buy current versions and downgrade ? or is this hardware and therefore not feasible ?
Cheers
stevie
Visit site
the reason a strong 4350 as well asa other receivers like
echostar work with a MM101 but not a MM102 / 103 is that
the fuse settings in the XILINX XC9536XL chip is different
if you put the same code into the XC9536XL
from the MM101 into the MM102
you then will get your cam working 100% in your strong
as well as getting the kiosk channels this as already been proved as i have done many now all with positive results
stevie
S
smeftahi
Many thanks for the tip,
But how do I go about transplanting the XC9536XL
from one to the other ?
Cheers
stevie
Visit site
well luckily these XC9536XL chips can be reprogrammed
so you need excellent soldering skills a programmer and adapter
for this type of device and the MM101 code itself
i can send you the code to do it yourself
or you can PM me if you want me to do the job for you
stevie
