Moteck motor doesn't move upon powering up Dreambox
badflyer
Dreambox 500s, 1.1m Triax, Stab motor
Birmingham, West Midlands
My STAB motor died after 7 years of use and i've replaced it with a moteck SG2100A. Everything is nearly ok with the new motor apart from the fact the motor doesn't want move when i initially power up my dreambox 500s! i've set a default fta boot up channel on 13E, so i would expect the motor to return to 13E on bootup, but it don't happen. If i manually select a channel using the remote the motor will turn, i.e a fta channel on 28E. Does anyone have any ideas what the problem could be? thanks
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Are you using USALS or Diseqc?
If using Diseqc1.2 the position settings in the motor won't match the receiver's.
I think you are going to have to go round saving all the positions from scratch, or use USALS/goto X.
Robbo:)
badflyer
I am using diseqc and have manually stored all my wanted satellite positions using the dreambox motor setup. Goto function is disabled. As i say, the problem only occurs upon booting up the box. Using the remote to switch to any of the saved satellite references once the box is up and running works fine. I'm puzzled...Could it be a power thing?
Don't think it's a motor thing, sounds more like a Dreambox problem. I don't have a default channel set, the box simply starts up where it left off. The DM500 is renowned for its lack of oomph in the power output department.
augy
satellite, files, firm, help, keys
ireland
Hi, that's a bad thing, I had the same problem, working on during 1 week and at the end I decided to go back to my other receiver which are working properly with my motor after a strong headache. May be later the technical solution will be found.
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
This is strange. My 5620 dreamboy always starts with the station it was on when turned off...what image are you using?
mhku
TM Nano ~ sg2100
Midlands
It's a 500 thing - lack of power.
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
With Gemini images, you can set this option if you press menu while viewing a bouquets channel list.
Yes, in fact I utilised this function after finding out about it, it can save embarrassment when starting up the Dreambox in company. ;) :-rofl2
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
:-rofl2 Exactly :D
gandalfthegrey
Specialised Contributor
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
dublin,ireland
happened to me a few weeks ago..My missus minds my niece and the girl next door came in to show off her newborn baby...the niece picks up the 500s remote,hit the power on button...on my TV when you turn on the dreambox it jumps from viewing N*L to the last channel watched on the dreambox...So it went to exactly where I had been the night before.....took some explaining....
I was gandalf the red that day :-rofl2
:-Guill
