Moteck SG-2100 Manual
For anyone who has lost their manual. :)
If anyone can't read any particular parts, steffan_st has uploaded a PDF below. :).
mhku
TM Nano ~ sg2100
Midlands
:rolleyes: who, me?
:D Thanks!
The Skipper
Dreambox 7000s
Worcestershire, UK
@rolfw
Is there any chance of doing a higher res copy of the manual please?
Or emailing me the pics?
I intend to buy one of these babies and always like a good read before I get stuff so that I know what I am doing and well prepared before it arrives :)
Much appreciated but fully understand if not possible.
Cheers,
Skip
steffan_st
A bit enthusiastic
Gibertini OP 125 L, Smart Titanium lnb with CD-80 feedhorn, Moteck SG-2500, Azbox HD Premium+, some 5 meters of good quality coax
Sweden
Here we go then!
rawill
SG100a, 1.1 dish, ulraplus780
New
Hunting around on google led me here. I can longer find my moteck manual and yoiu have saved me!
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
i have the bigsat diseqec motor,is this the same modell,and a oem product of moteck?
iam not exactly sure?
romc
90" Dish, Ferguson and SG-2100
Poland
I just got Sg-2100, In my manual the base angle is 30 Deg not 40 Deg? And when using DishPointer.com the correct angle should be 30 Deg. What's up with that?
satelliteman
There are two types with different shafts :)
Yes, I believe they changed it on the newer versions (this post is three years old), so go by your manual.
What I would say though, is forget about the declination angle, as long as the latitude is correctly set on the motor body, just set your dish so that the dish face is slightly off the vertical and find your due South satellite using a small meter and adjusting the dish bracket until you get the strongest signal, then you have the perfect declination setting.
sideswiper
Motorola DSR-922, Diamond 9000HD, Techno Trend TT3200, Coolsat 5000, Viewsat Ultra,Pansat 2700,Two Prefect 10, 10 foot C Band Dishes Norsat Titan, BSC-621 LNBFs,Vbox2, 30 Inch Fortec Star, Moteck SG 2100 Motor, Invacom QPH-031 LNBF.
Ontario, Canada
Thanx it saved me from looking for my manual wasnt sure how to reset the motor, had to do a factory reset on the Diamond so i have to redo everything thanx again
hotkich
tm 7755 2VA 2CI / & tm 6900super/
80 cm dish motex motorised/
echostar 3000ip /moteck SG1200 CHIMNEY SECURED
france ST GENIS D HIERSAC
thankyou , I have just purchased a SG2 100A (from our satshop pulsat) after the the same type gave up the ghost, somehow it twisted to the extream west and siezed up ?
having had a quick look at your ref, I must say its seems quite reasonable to attempt at my age, good luck ROLFW and thankyou again
hotkich::-worship
