Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Motor won't do its job properly
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="GJ89" data-source="post: 742755" data-attributes="member: 360984"><p>Just come back, and wow, it actually worked! I've only tested getting to 16E now but the peaks for Astra 1 in signal strength have convinced me it'll be no problem getting there either... it still requires fine tuning but as it's getting dark I've decided to postpone that to tomorrow <img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /> I'll put on another pic of the current latitude in a moment (damn hard to adjust).</p><p></p><p>It seems I've been a bit of an ass, as the dish was very loosely adjusted to the motor, it's solid as a rock now. The LNB was not 100% right, not like it matters much it seems, but it's been adjusted. Due to it all being attached like a polyester sweater it nearly collapsed yesterday so it required me to completely switch all sides again. Used USALS 5.9E directing to 4.8E afterwards to locate Astra 4A.</p><p></p><p>The transponders is indeed a thing I walk into, but lately I've been selecting those beforehand, taking notice of the fact the transponder might be active on multiple satellites, and if they have channels that I usually watch.</p><p></p><p>Thank you all for your input and I'll share the new latitude photo tomorrow for your approval <img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="GJ89, post: 742755, member: 360984"] Just come back, and wow, it actually worked! I've only tested getting to 16E now but the peaks for Astra 1 in signal strength have convinced me it'll be no problem getting there either... it still requires fine tuning but as it's getting dark I've decided to postpone that to tomorrow :) I'll put on another pic of the current latitude in a moment (damn hard to adjust). It seems I've been a bit of an ass, as the dish was very loosely adjusted to the motor, it's solid as a rock now. The LNB was not 100% right, not like it matters much it seems, but it's been adjusted. Due to it all being attached like a polyester sweater it nearly collapsed yesterday so it required me to completely switch all sides again. Used USALS 5.9E directing to 4.8E afterwards to locate Astra 4A. The transponders is indeed a thing I walk into, but lately I've been selecting those beforehand, taking notice of the fact the transponder might be active on multiple satellites, and if they have channels that I usually watch. Thank you all for your input and I'll share the new latitude photo tomorrow for your approval :) [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
