eubster
- Oct 31, 2008
- Age
- 47
- Humax HD Freesat Box, Visiosat 90cm Dish. Inverto Black Ultra Quattro LNB. EMP Centauri MS5-8PIU-4 MultiSwitch
- Toulouse, France
Hi all,
I'm a long time follower but pretty new poster so bear with me
I need some help with a multiswitch setup I'm trying to install. Sorry for the long post, but I hope it will avoid lots of questions.
I'm based in Southern France watching free to air UK channels and French Terrestrial digital TV. For the last year I've had a 90cm dish set up on Astra 2D 28.2E with an MTI QUAD LNB distributing a sat feed to 4 rooms with the terrestrial feed directly to a TV in another room. Satellite signal is more or less perfect (100% signal strength and quality on my freesat box).
Now I'm renovating I'd like to use a Multiswitch to combine the Satellite and terrestrial feed and send it to 6 rooms in the house.
I've bought an EMP-Centauri P.143-UP (MS5/8PIU-4) Multiswitch which is apparently QUAD compatible, wired up the QUAD LNB and terrestrial inputs to the Multiswitch and connected each room feed to the outputs. Unused outputs are terminated and the whole unit is earthed.
In each room I've got a LEGRAND Celiane faceplate which splits the signal into TV, SAT and FM frequency bands.
Now the problem...when it's all wired up and switched on, the freesat box indicates a signal problem. When the diagnostic runs, I can see the the satellite is still 28.2E and the signal strength remains 100%, but the signal quality is 0%.
When I manual tune, some transponders have 100% signal strength and quality, but many others have 0% quality.
Does anyone have any experience of this kind of issue...and how to solve it. Thanks to all in advance
