Zebethyal
- Jun 9, 2008
- Age
- 56
60cm dish, quattro feed Astra 2A, multiswitch
60cm dish, dual feed Astra 1A, dual feed Hotbird
90cm dish, dual feed trackable, Vbox II
4 way Diseqc switches
Triplex outlets
Sky+
Twinhan DVB with Diablo card
- Harrow
Hi All,
I am having problems with my latest dish setup:
60cm standard dish, quattro LNB, Vision 5x16 multiswitch, sky+
I am also feeding TV and FM via a triplexer into the common input of the multiswitch.
If I connect a standard sky box to any of the outlets from the multiswitch - no problems, all channels accessible, good locked signal shown, good tone from satellite finder if connected between output and receiver.
If I connect my Sky+ box, it says no signal on either of the 2 cables connected, satellite finder powers off when cable is connected.
LNB settings on both boxes are the same:
lo band low 9.75
high band low 10.60
22kHz tone on
LNB power on
Same cables used for both receivers, just swap the cables between tests.
The Sky+ box was working fine with a minidish and quad LNB but does not want to know about the multiswitch.
Cables in question are not currently connected via triplex outlet plate, although second cable would only have a standard f type connection anyway, they are being used directly with f-type connectors straight into the satellite boxes.
I do have additional outlet plates, just not used them in that room yet.
Any ideas? all offers of help gratefully received.
lo band low 9.75
high band low 10.60
22kHz tone on
LNB power on
