OldBen
Mad Scientist
- Jul 29, 2005
- Age
- 47
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch. VU+ Duo. Emitor Satlook Lite meter.(Retired: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB
- UK
Ok, almost understand everything I need for simple multiswitch setup I want now, but final question relates to combining FM/DAB/TV aerials into multiswitch, I see two options:
Option A:
FM -> Triplexor
DAB -> Triplexor
UHF -> Amp -> Triplexor
Triplexor -> multiswitch
Option B:
FM -> Amp
DAB -> Amp
UHF -> Amp
Amp -> Multiswitch
Which is the usual way to do it
Won't be using a masthead amp, as apart from service issues, come switchover in 2012 possibly too much gain, although I need quite a bit of boost until then for UHF HD Mux. Plan to run all three aerial feeds into loftspace, then combine inside before running to multiswitch location also inside.
My understanding is most multiswitches don't have terrestrial amplification (but do have loss) as they are usually with launch amps and what not so I do need some amping before multiswitch, do I need to amp FM/DAB as well?
Option A:
FM -> Triplexor
DAB -> Triplexor
Option B:
FM -> Amp
DAB -> Amp
UHF -> Amp
Amp -> Multiswitch
