H
hoppo1
I have looked & looked for how to change the keys manually & failed. Now to rub salt in the wound'O'-red the new firmware says T*S & Multi****n all ok just ""Do a "reset keys (smartcard,reset data,all)" to make it work.
All well & dandy, but my menu screen has no smartcard option & neither do the sub menus.
What do i need to do to find the "hidden" menu, or what do i need to do with the receiver to get it read a menu (if you know what mean?
The receiver info shows that the new software is loaded by the way.
Cheers guys,
Hoppo1
Cheers guys,
Hoppo1
