My c-band plans
R
Rd100
I am going to buy another 1.8m prime focus dish and c-band lnb-f volt switching lnb this week,
And am going to have a go at modding a prime focus c-band lnb-fforuse on a small offset dish,
CROSSBONES
S.Wales
Is the prodelin dish installed yet mate?
What make 1.8 are you going to get?
Should be interesting to see what you can get on a small offset;)
Please keep us informed:)
R
Rd100
I have used the 1.8m prodelin on a ground mount but have packed it back up untill i move house,
For use on c-band i am going to get prime focus dish and a c-band lnb-f but am going to try and make a offset feedhorn aswell to use on a small dish
paaa
pppppp
united
hello there what sat can you receive through c band with dish?
pride21
Sandown Isle of Wight
hi rd the holder for my 1.2mtr offset dish for c-band i used 52mm copper tubing cut 1inch of it then cut it in half soldered 4 lugs to the two halves thats the cradle to hold lnb then made the rest up to fit dish similar to ku holder,for the offset scaler ring i cut a normal scaler ring in three parts then with six small brackets bolted the brackets to the three parts so each part is staggered then put 1 inch wide ali inside all the three parts it gives you more gain.
