My Dish From Greece
MCelliotG
Thessaloniki, Greece
Not with the Moteck rotor!
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Don't see why not. The closer to equator you are, the wider the arc you get.
Can't recall the exact hardware limits of Motecks and their clones, but I think with the set screws at max. it's 70 deg each way, so 140 deg of rotation. I set mine at 60, which is mechanically conservative and also sufficient for the visible arc at my Latitude.
stel883_
Vátika, Greece
The 1 meter dish at 30 west.
MCelliotG
You are lucky these trees don't block Hispasat, but I don't think you can go any further. Perhaps try 34.5W 11557H with the Televisa channels, this TP is very strong.
stel883_
Vátika, Greece
I drove the motor to 70.5 east, to see if the arc is tracking correctly and it isn't. I got 60 east clearing channels, so i have to re-align, zero to 23.5 east gives a small nudge on the motor :(
You may find the error is down to the weight of the dish components distorting the motor clamp behind the pole. There is not much you can do except a bit of intuitive realignment of the arc to compensate for the sag.
stel883_
Vátika, Greece
I will try later for 34.5 west, after re-aligning the dish!
stel883_
Vátika, Greece
O.k, i think i found where i went wrong, i thought my zero was at exactly 23.5 east, but it's at 23.0 east, that explains the small nudge :)
stel883_
Vátika, Greece
Plus, i used a different receiver not set in Usuals for tweaking the signal!
A good signal in one direction and nudging in the other suggests it was not solely down to the Longitude setting.
Have you got the same signal measurements at the 60E position after changing the coordinates ?
stel883_
Vátika, Greece
I just spoke to my friend who did the install with me, and he said we hadn't tweaked the motor yesterday, coz' not enough time.
MCelliotG
Honestly though, if you can find a place on your rooftop with a clearer and wider south view, it's best to move the dish there.
stel883_
Vátika, Greece
I haven't actually changed my lat & long in the receiver.
stel883_
Vátika, Greece
I have a tall tree towards the south, so i don't think that is an option.
stel883_
Vátika, Greece
Here is the tree, 1 meter dish is at 23.5 east.
stel883_
Vátika, Greece
I did a re-alignment last night, managed to get to 70.5 east, but i could only clear up to 7 east :(
Will try again tonight, i was trying to tweak 28.2 east.
stel883_
Vátika, Greece
O.k, i finally understood that zero is for alignment purposes only!
I re-aligned dish and managed to get to 34.5 west with signal, still need to move east though.
stel883_
Vátika, Greece
I moved to 70.5 east and cleared a channel! I did notice some lower readings on 30 & 22 & 15 & 8 & 5 west and 3 & 4.8 & 66 & 70.5 east.
