My motorised setup
sg_
45w-52e 80cm VU+ Duo2 (DVB-S/DVB-T)
Northern Ireland
Its an 80 cm (unbranded) and I have reception from 45e to 45w. I think the garage is in the way for anything further than 45e :-doh2.
Twin output LNB, one goes through the motor to my reciever for control, and the other goes directly to my dvb-s2 pci card. Other than that, its nothing really too fancy.
Some pics are below of the dish at 45 east and 45 west along with a few of the underside showing the wiring.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Nice pictures:)
Just one thing though, I wondered why you have put the wall bracket on upside down?
I think I would be a bit worried that should the nuts come a bit loose, someone is going to get donked on the head.
Robbo:)
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
Robbo71 said:
Nice pictures:)
Robbo:)
This looks quite like mine and although i have put my bracket the way you suggest the recommended way to have it is the way he has fitted it, as any water runs out the bottom and does not pool in the bend of the bracket.
satelliteman
The L type stand off is up side down although it doesn't really matter
.............best hope your nuts don't become loose .......... :-cry1
Neat job, WD
sg_
Northern Ireland
Thanks.
Dont worry, they are on tight enough and it has been up for over 1 year already :D
I really hope to upgrade it sometime sometime within the next 6 months to something better :)
satelliteman
Get yourself a couple of 12 inch TK brackets when you upgrade :D
