My Programmer
C
c9679
Hello, Can someone please help me with this... im really stuck :(
I purchased a programmer from a company 2 weeks ago, its finally arrived, I cant get in touch with the company because they dont answer the phone or any of my emails :(
I really desperately need to program a 12C672 pic chip, I have everything ready but I have no idea how to use this programmer
http://secure.smartchips.net/acatalog/Online_Catalog_PIC___Eeprom_programmers_1.html
Mini Pic Pro
All i received with the programmer was a floppy disk with ICProg, i do know how to use this program but im not too sure which programmer to select from their choice of programmers, obviously theres no mention of Mini Pic Pro, however does anyone know if this programmer might have another name please???
Thank You :)
C
c9679
Hello, Thank you so much for your reply...
I did select JDM as the programmer as there where only 2 options that where serial programmers and JDM was the only one that supports 12C672
The problem is its not writting to the chip, when i click on program all it looks like its doing then about 20 minutes later it starts doing the verify and it fails with an error message at 00000h
When I open the hex file i need to program, and select Verify on its own it always fails with the same error message however, if i dont open a hex file and all the settings remain the same Verify is successfull
Im just not too sure how to program this Pic Chip, ive tried everything i could think of :(
nobbly
Not in UK
In IC-Prog hardware settings set the programmer type to JDM
Direct I/O enabled
I/O delay 4
you could also try inverting the VCC.
nobbly :+
