Need A New Internal Satellite Card For PC
Can anyone recommend me a good internal satellite card for a PC ?
Requirements are:
1. Sensitive tuner
2. Widest possible tuning range
3. 4.2.2 capable for both SD and HD
4. Any other useful functionality for feeds etc
Thx
The Hauppauge WinTV Nova HD card should meet your needs. Good with low symbol rates and a reasonably sensitive tuner.
4:2:2 capability will depend on codecs used in your application. Elecard will manage that.
DVBviewer Pro and its Transedit plugin as your application for scanning functions, stream analyser etc.
Llew,
Would you know if the Hauppauge card you mentioned above is supported with drivers for Windows 7 64 bit version ?
Rgds
Yes. Use it myself with Win7 64bit.
