need help
uglybear
looking at getting a dreambox is there anything i should know or any additional pieces of kit i wll need also im on a equim note book on vista can some one give me the web site to get the codes that i will need
worcestershire
got a dreambox 7020 going through the manual done everything that i should have but keep getting a message ALL KNOWN TRANSPONDERS HAVE BEEN TRIED ....NO LOCK WAS POSSIBLE. VERIFY ANTENI CABLE-SETUP ???????
would be greatfull for some assistance
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Welcome to the forum uglybear
Please take your caps lock off ....it is considered to be shouting...
There is not sufficient information for anyone to be able to help you. What dish do you have, what lnb? is the dish correctly aligned, has it been used before what direction is it pointing. What grade of satellite cable has been used.
mhku
TM Nano ~ sg2100
Midlands
Welcome to the forum :)
Are you using a motor? The message means the dish isn't pointing at the satellite it expects (or none at all). Which satellite are you pointing at?
