Need info about dvb card
r0ny
DM500S
india
I would like to know the model names of some dvb cards which is equivalent to a dreambox receiver,i can load stuffs like cams etc,mpeg4 streams ,and stuff like that,Thanks in Advance
portly
Bush freesat hd box, iss 70cm dish,single passion lnb , goodmans GDB15HD freeview box
heathrow
Youll be lucky :-rofl2 there are good dvb cards out there but as good as a dreambox , me not think so:eek: although i could be wrong. google for card manufactures or check posts here
Low Profile
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
Is a Skystar2 that different to the functionality of a dreambox?
Under a LINUX o/s you can run CCcam, under Windows you can run WinCSC + others (flycam, Gbox, Mbox etc), you can run emulators - S2Emu, V_Plug, Emunation etc, you can record to hard drive, watch 4:2:2 streams, Blindscan (with V2.3), you can stream to LAN. The 'only' thing is that it's not stand alone and does not have a built in card reader.
