network problem
moosegoose
bog standard
80 cm dish hh motor teco tm1000 dreambox 7020
cas 3interface
dragon cam.promax tv explorer 2.
norwich
hi hi i got a db 7020 connected to a router with Gemini installed and mgcamd 130. hack sat has been a bit slow lately so i thought i would ftp the latest keys. but it will not seem to connect using dcc. also web interface has stopped working just comes up with log in screen but wont connect. the db connects to the Internet ok as i tried installing a game and it worked. i also ping it from the router and all was fine. so the problem seems to be from the laptop to the dream box. when i connect using dcc it say socket not connected. previously this evening i was trying to connect a sat meter to the laptop and i changed one of the com ports so i don't know if i have messed something up if u got any ideas please reply as im now stumped.
moosegoose
bog standard
cas 3interface
norwich
i can also usually connect to the web interface with ny nokia mobile but thats not working now. so its not just the laptop.
d122k7trb
Judas Priest
IClass Receiver
2 Premium X LNBs Hotbird+ Nilesat
120" Dish
Computer system:
AMD Phenom Quad quad core 9750
4GB DDR2 Bus 800 RAM
MB: Asus Crosshair
1 TB Seagate Barracuda 32 MB cache
22" LCD Widescreen Samsung 226BW
SB X-Fi Xtreme
Armenia, ME: The Arab Countries
Did you cheked the hardware itself?
Maybe the socket has problems or there's somthing wrong with pins.
The software may also has problems, too.
mhku
TM Nano ~ sg2100
Midlands
Have you tried with your Firewall disabled? Are you running Peer Guardian?
Have you checked the IP settings in DCC (I don't use it so can't help with specifics)?
Have you tried using an FTP program e.g. FileZilla, or Internet Explorer, to FTP the files over?
moosegoose
bog standard
cas 3interface
norwich
i will try tonight many thanks
