New dark box channel 4 +5
bwizz
bwizz
darkbox rev2007 Reciever + old pace sky box
70 CM OVAL DISH
multi lnb
Cornwall UK
My new darkbox sees channel 4 as scambled , but my FV sky card clears 4 but I can't find channel 5 , I am missing something obvious here
_www.lyngsat.com will give you the frequencies for Five, make sure that they are listed in your receiver.
The frequency is probably missing from the database (C5 changed a few months back) - Add 10964H 22000 5/6 and it should work fine.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Channel 4 is in the clear on 2D, you should not need the card for it on 10729V.
Robbo:)
bwizz
bwizz
70 CM OVAL DISH
multi lnb
Cornwall UK
I am not sure that I am on 2d i have all the usuall sky ftv stuff ,but 4 is certainly scrambled and sky card clears it
still tryng to get my head round identifying satellites , my original idea of using the old sky box on the roof !does not work as it only sees certain satellites
Astra 2D is co-located with the other satellites at 28.2 East, so if you are getting FTV channels like Sky 3, you are also pointing at 2D.
bwizz
bwizz
70 CM OVAL DISH
multi lnb
Cornwall UK
I don't remember seeing sky3 but i do have all bbc and itv regional tv which i was suprised to see
_http://www.lyngsat.com/28east.html shows the satellites parked at 28.2 East and the channels broadcast from them.
Robbo
Retired Mod
Gravesend,Kent,UK
I think, but I don't know, that there are two channel 4's,
if you scan the transponder I stated you should get the FTA one.:)
(Not that it matters too much at the moment if you have a Darkbox and an FTV card)
But you should get Sky 3, its on my Sky Dodgibox with FTV card.
