ipbr21054
- Aug 4, 2011
- Age
- 56
- XP pro with DVT S
- south west uk
Today i have purchsed the DVB S usb stick.
I have been trying to set it up but not much luck.
Reading through a few posts did not give me the answer i was looking for.
After installing the drivers correctly & the software that came with the stick i am presented with Blaze DTV 6.0
There are many settings "or looks that way to a novice " to be entered.
I have the usb connected to the Sky dish cable.
Reading a previous post,nearly 2 years old i have managed to find 330 after a scan BUT many of the have a star by them and no picture shown
when that channel selected.
I dont even get the standard freesat channels when a search is completed,i believe this is down to the incorrect settings entered by myself.
Any advice would be good so i can scan for viewable channels.
Questions asked are as follow.
Select Satellite.
Transponder type
LOF1 & 2 setting in MHz.
If you are able to give some advice i would be gratefull & if screen shots are required then i can do that.
Thanks very much.
Select Satellite.
Transponder type
Thanks very much.
