- Sep 28, 2005
- Dream7020 and AZ Elite and a few DM800
- Sweden
[Firmware] 0.9.2163
Release Notes
This release is the firmware for testing new drivers with following features:
- Scart RGB
- LATM audio codec
- 4.2.2 HD content (not fully supported)
- DTS
Added
- Support WPA2
Added
- Create Menu Network Services, Between Internet and Storage: possible active / desactive and configure: SMBD, SSHD, FTPD, TelnetD, interface
Fixed
- When receiver boot network IP is set correctly, but gateway and/or name server takes too much time.
Fixed
- At DVB Subtitles, you can see the subtitles but when you select the subtitles only show first languages of list (example: Digi TV 1¨¬W).
Fixed
- Activate ¡°move¡± channels on list, possible to move one channel or group of channels at same time
Fixed
- If receiver is plugged during several hours at HD channel Time shift and pause stops working
(Pause works but only for 2 seconds), only way to make box return to NORMAL is reboot.
Fixed
- At time shift options |<< & >>| button should seek the 10% position of buffer
Fixed
- When change password on parental control and lock, password is not changed at LOCK on channel list.
Fixed
- At Movie Player, add option to turn OFF subtitles or messages, if no subtitles or message come after 3 seconds. Basically need optimization of subtitles, still sometime appear at MKV the subtitles messages during several minutes without go out.
Fixed
- When picture resolution is higher than 2Mpix, AzBox wants to start optimization, but never finish.
Fixed
- In "FTP Manager" you cannot exit like all the other menus with the exit button, only with Home button.
Fixed
- When change root password keep changed password when reboot, very URGENT for safety reasons (THIS IS VERY CRITICAL AND VERY IMPORTANT).
After updating, root password will be removed.
Fixed
- Satellite Nilesat 101/102/Atlantic Bird 4 (7 ¡Æ W) is missing in the satellite list
Fixed
- Error executing the menu item "Delete All Channels. The lists "genre" and "countries" are not deleted. Only factory reset will restore the two lists.
Fixed
- Start search/browse subtitles in movie directory (especially useful when we watch from LAN and have long URL).
Fixed
- Backup RSS reader address, now after update everything is deleted
Fixed
- If You-tube is forbidden on router and then try to open You-tube on azbox , of course will not be possible to show video, however when you go for a TV channel, you get a surprise picture in windows have resolution of youtube ( 1/4 of full screen). You must restart box for NORMAL picture
Download from the net into the box, 45MB
Release Notes
- Scart RGB
- LATM audio codec
- DTS
Added
- Support WPA2
Added
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
