New software for srx150D-SRX200Ci plus
adaroubala
I have upload str3680_tps_ok to my strong 3680. But, when I switch off and on my receiver I have Err0 message.
Help me to fix this error
Asif
Does any one here know how to enter tyhe code starsat X-3100CU i did patch it from www.satsw.com but i am not getting the hidden code, insted i get INPUT CODE what is this, does any one has the orignal software for this model plz help.
Asif
Alexy
Dear Friends Would U Plz Tell Me What Is The Difference Between The Patch V.255 And The One 256, I Wanna Know Which More Channels Are Opened Than V.255!!!
And My Next Question Is; Isn't V.255 Renamed In Satsw.com, Is It 256 With The Wrong Name Of 255???
Thx Alot, Plz Help.....
nhfs49
Starsat,Strong, Onyx, Omax, Astrasat, Condor, Starcom, Astrovox, JTAG.
Laptop,Desktop.
Lebanon
Dear, this two versions are the same. maybe they change frequencies in some sats.
rahmouen
HI:
:) New Software for star sat and star com :)
The last update in 10-1-2005 for srx 120 130 150 d 1M and 2M
v 210 v 310 v7 new
notes:
go to the www.satsw.com an you will find that
and another version for star com or star sat srx 150d
:rolleyes:
REARAB
hi plz tell me how can i upgrade my receiver the model off my receiver is starsat srx150d mk II
THANK YOU REZA
chiripo
biss for Starlife / Starsat
guatemala
Hello, I have a question. I have a starsat 150d and a 200CI. But I know that they are similar to emtech receivers and others too. I was wondering if I can change the firmware from my receiver to other similar to it, like the one emtech use?
thank you
gigi13
Emtech 200
PC XP
GREECE
I have the opposite probleme but quite similar. I have a emtech em 200 and I was wondering if I can use any other soft such as starsat because I cant get any new.
Anyone?
mdagohoy
yes you can use the STARSAT SRX200CI sw for your emtech. it works.
Mohammed Saeed Akram
Dear.
I need the latest update software and key code for my
star sat sr-x200ci plus .if anyone have it ,please send to my
Email address removed
Regards,
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
visit satdw.com
hadia
Star-sat srx 150D+
iran
Hi I'm looking for the loader and program for this SRV
could you help me please
Cheers
S
waseemahmad76
USERS
Saudi Arab
HI EVRY BODY
i need SR-X150D anf SR-X120D Updated Softwars and eMuploader software.
BEcause i want to Update my receivers.
Email:REMOVED
I will be very thankful to whom will helme to get the required softwares
