New Softwere For All Receivers
harris
Link removed - I believe the site carries virus files.....
Hassan44
am sorry harris but ,,,,,,,
the files are loaded with backdoor trojans........
beware .....({})
byaari
what cable should i use to connect rs232 port of my receiver(strong 4400) to com1/2 port of my computer for upgrading of my receiver? what is a modem cable?
byaari said:
what cable should i use to connect rs232 port of my receiver(strong 4400) to com1/2 port of my computer? what is a modem cable?
Probably a null modem cable, a specially wired cable that cross wires some of the connections at each end of the cable.
byaari
can you plz tell me the wiring specially the number of crosslinked wires?
san
hi byaari vbmenu_register("postmenu_158334", true);
wich kind of receiver do you want to upgrade via pc ?
plz post repply then ill explain about rs 232 c null modem cable:)
martynas
hay, im new here, could anybody explain how to upgrade software of digital receiver Star Track NC-707 via pc through RS 232C cable? and where i could find software for it?
Digital2
Dreambox 500s,Dreambox 800HD PVR,Max 1000,Vivax 505, Starsat 200CI. Desktop with WinXP, Laptop with Vista & Netbook with Win7. External HD/Media Recorder.Hotbird,Nilesat,Asiasat3S & Intelsat.
Middle East (Currently!)
Go to the site for Star Track www.starsw.com. Good Luck :)
martynas
sorry mate,but there is no luck in that site, i made that cable with 3 wires or i need todo with all of them? there is no explanation how to upload, im gonna kill myself with this headache
omegalover
hi guys
could anybody tell me if star track nc-707 can open new channels apart from the tps and absat and the polsat group?
sohils
star track
qatar
i tooo have a brand new NC-707.
the signal and workin is amazing
hope toget a s\w for dis as fast as possible
plz help me
