TimeShift
- Feb 11, 2011
- Age
- 44
- TM600 + Dm800 HD
- UK
I was thinking of buying a second hand ex sub one from ebay, just for the free channels, e.g. Five, Fiver, Five USA and so on and sticking it in a TM600
My question is, the card will already have been paired to the original sky box and as it's an ex sub card will i need the original sky box serial to input in to the TM600 and will the card still need to have entitlements updated???
Also if I go down the route of buying a free-sat from sky card directly from sky, and then activating in my original sky SD box, will I still need the box serial and still need to update the entitlements???
Also if I get a free-sat from sky card directly from sky, and then activate it in a normal non HD sky digibox, will the HD channels clear and work in a DM800 HD box??? or will the free-sat from sky card need to be activated in an HD digibox???
This is the only reason I would go down the ebay route as I do not have an HD sky digibox if it is needed to activate the HD channels
Any help on this please, thanks.
TimeShift.
TimeShift.
