newbie plz help
baashi
im newbie i have no idea about sattellitte tv and i want to wtch premiership matches so any help will be needed thanks.
this is the equipment i got but i dont knw if is the rite one
100cm Hi-Gain Soild Satellite Dish
DiSEqC 1.2/1.3 Usals Satellite
london
i have just bought 1m MOTORISED SATELLITE DISH DiSEqC 1.2 MOTOR + 0.2 LNB here is the link
http://cgi.ebay.co.uk/1m-MOTORISED-SATELLITE-DISH-DiSEqC-1-2-MOTOR-0-2-LNB-/220356240463?cmd=ViewItem&pt=UK_ConEle_SatCableFreeview_RL&hash=item334e41644f
i would like to ask some question as i want to watch premier league matches next season is this package good to watch prem matches also do i got tm1000d+ so do they go together and if i connect them together can i watch the matches if not what do i need to do thank u
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
In that case you will need to buy a subscription from sky and a sky stb from ebay, nobody can watch Premiership football for free unless they card share and for that you would need a Linux based stb
satelliteman
Hi Baashi.
It's worth noting that a 550mm Steel Wall Mount will not support a 100cm without it's problems.
A good set of TK brackets required.
How much are you willing to spend on subscriptions?? There are no freebies these days for Prem games
The best subs are a thousand quid a year and have to use a uk based reseller - (or 1500 if you want HD channels as well!) :D
baashi
london
satelliteman said:
Hi Baashi.
so this wall mount is useless can u recomend me any site that is selling tk brackets m8 also is tm1000 good thanks
baashi
london
thanks for the reply all i want to watch is the rsenal games no hd how much will that be m8
baashi
london
how can i do cardshare m8 also how can i get linux based stb thank you for the reply
Topper
Nobody has time to walk you through this, if you want to know how to do these things you have to learn how by reading the appropriate section of the forum. But if you do not start now you may not be ready for the start of the new season as that is how long it will take you to feel comfortable with the stb, they are definitely not plug and play
I would also point out that on this forum m8 is not considered a polite way of addressing people as indeed is any form of text speak
satelliteman
In a nutshell, yes.
Try >> Satellites UK site Sponsors or a quick search around the net.
